#1 Fri 23 May 2014 11:08
- florence44
- Lieu: CARQUEFOU (44)
Traducteur universel
Bonjour, depuis quelques jours mon traducteur universel ne fonctionne plus, voici ce qu'il me dit à la fin du rapport :
Lecture de fichier en cours
FME 2013 SP1 (20130319 - Build 13448 - WIN32)
FME_HOME is 'C:\Program Files (x86)\MapInfo\Professional\UT\'
MapInfo.UniversalTranslator
Permanent License.
Machine host name is: br-HP
START - ProcessID: 6500, peak process memory usage: 26396 kB, current process memory usage: 26396 kB
FME Configuration: Command line arguments are `C:\Program Files (x86)\MapInfo\Professional\UT\fme' `C:\Users\Florence\AppData\Local\Temp\fme-control-Uh6636.tmp' `LOG_STANDARDOUT' `YES'
FME Configuration: Reader Keyword is `MAPINFO'
FME Configuration: Writer Keyword is `SHAPE'
FME Configuration: Writer Group Definition Keyword is `SHAPE_DEF'
FME Configuration: Reader type is `MAPINFO'
FME Configuration: Writer type is `SHAPE'
FME Configuration: No destination coordinate system set
FME Configuration: Current working directory is `C:\Users\Florence\Desktop\shp'
FME Configuration: Temporary directory is `C:\Users\Florence\AppData\Local\Temp'
FME Configuration: FME_HOME is `C:\Program Files (x86)\MapInfo\Professional\UT\'
FME Configuration: FME_BASE is 'yes'
FME Configuration: FME_MF_DIR is 'C:\Users\Florence\AppData\Local\Temp/'
FME Configuration: FME_MF_NAME is 'fme-control-Uh6636.tmp'
FME Configuration: FME_PRODUCT_NAME is '2013 SP1'
System Status: 245668MB of disk space available in the FME temporary directory (C:\Users\Florence\AppData\Local\Temp\)
System Status: 3923MB of virtual memory available
Operating System: Microsoft Windows 7 64-bit Service Pack 1 (Build 7601)
FME Platform: WIN32
Locale: fr_FR
Code Page: 1252 (ANSI - latin I)
FME Configuration: Process limit is 4038 MB (out of 4038 MB physical memory and 4095 MB address space)
FME Configuration: Start freeing memory when process usage exceeds 2423 MB of memory or 3495 MB of address space
FME Configuration: Stop freeing memory when process usage is below 1817 MB of memory and 2621 MB of address space
FME Configuration: Autodetermining optimal maximum number of objects in memory
Trying to find a DYNAMIC plugin for reader named `MAPINFO'
Using MapInfo (MFAL) Native Reader $Revision: 101505 $ ( $Date: 2013-02-19 15:48:28 -0800 (Tue, 19 Feb 2013) $ ) to read MapInfo data from directory `C:\Users\Florence\Desktop\shp\'
MAPINFO Reader: Using Enhanced Geometry
No specified layers were found in MapInfo Dataset 'H:\SECTEUR....
Translation FAILED.
Traduction terminée
Florence
#2 Fri 23 May 2014 15:07
- Daniel
- Lieu: Victoriaville, Québec
Re: Traducteur universel
Avez-vous fait un test avec un fichier que vous aviez déjà transformé?
Si je lis bien, vous voulez prendre un TAB pour le transformer en SHP! Votre TAB est bien fait? Tous les fichier Mapinfo (TAB, MAP, DAT et ID) sont présent dans votre répertoire? Aucun problème à l'ouvrir dans Mapinfo?
Je lance des perches mais je ne comprends pas pourquoi ça fait cela?
Daniel
De retour à la géomatique
#3 Fri 23 May 2014 15:13
- Benoit91
N'ayant pas suffisamment d'infos je vais faire comme Daniel, je lance des perches...
Quelle est la taille de votre fichier ?
Avez-vous suffisamment de place de stockage à l'endroit où vous souhaitez enregistrer le fichier ?
Le chemin d'accès au fichier n'est-il pas trop long ?
Avez-vous essayé en le mettant sur votre disk ?
Une mise à jour du PC qui causerait le problème ?
#4 Fri 23 May 2014 15:21
- florence44
Oui j'ai essayé d'autres fichiers, déplacé mes fichiers en local ... mais c'est pareil.
#5 Fri 23 May 2014 16:06
- Benoit91
Est-ce que vous avez le même message pour tous les fichiers que vous tentez de traduire ?
Car le rapport posté indique un problème de localisation du fichier a traiter
Dernière modification par Benoit91 (Fri 23 May 2014 16:06)
#6 Fri 23 May 2014 16:37
- florence44
non le message change par rapport à l'emplacement du fichier, c'est étrange j'ai des exports qui ont fonctionnés cet après-midi, ça serait donc plutôt un problème des fichiers mapinfo mais ça ne m'est jamais arrivé avant !
Florence
#7 Fri 23 May 2014 17:02
- Benoit91
j'ai déjà rencontré des problème de transformation de données.
Il se peut qu'il y ai un caractère dans un champ qui ne passe pas, mais en général dans le rapport il est indiqué.
ou peut-être une géométrie trop complexe...
Avez-vous compacté la table ? (si c'est pour du tab vers shp)
Dernière modification par Benoit91 (Fri 23 May 2014 17:02)
#8 Fri 23 May 2014 17:05
- florence44
Non je n'ai pas compacté la table, mais j'ai aussi des données venant de l'extérieur !
#9 Fri 23 May 2014 17:34
- Daniel
Salut
Je viens de me rappeler de certains problèmes que j'ai déjà eu.
Comme vous avez des fichiers qui proviennent d'ailleurs et qu'il peut y avoir certains problèmes, essayer ceci :
1- Exporter vos données Mapinfo en utilisant Table - Export - Mif/Mid
2- Réimporter vos données Mif/Mid en TAB en utilisant le Table - Import
3- Réessayer l'exportation TAB vers SHP en utilisant le TU.
Donner des nouvelles!!! Si ça fonctionne, verre de vin!!! Sinon... verre de vin aussi!
Daniel ![]()
#10 Sun 25 May 2014 19:09
- Spacejo
- Lieu: Nancy
Une alternative sans Mapinfo pour voir si ce n'est pas tes fichiers qui posent problème.
---> http://ogr2gui.ca/fr/index.php
+1 avec toi Daniel ![]()
Si tu trouves des sandres, tu peux les balancer par ici ![]()
Joël
