#1 Wed 10 June 2015 08:35
Robin
GeoRezo forever
Arcgis 10.X - Geospatial Modelling Environment (ex-Hawth tools)
http://www.spatialecology.com/gme/
Anciennement appelé Hawth tools, ces outils spatiaux sont utilisables / scriptables sans avoir besoin d'ouvrir Arcgis (mais nécessitent son installation) smile
GME provides you with a suite of analysis and modelling tools, ranging from small 'building blocks' that you can use to construct a sophisticated work-flow, to completely self-contained analysis programs. It also uses the extraordinarily powerful open source software R as the statistical engine to drive some of the analysis tools. One of the many strengths of R is that it is open source, completely transparent and well documented: important characteristics for any scientific analytical software.
GME incorporates most of the functionality of its predecessor, HawthsTools, but with some important improvements. It has a greater range of analysis and modelling tools, supports batch processing, offers new graphing functionality, automatically records work-flows for future reference, supports geodatabases, and can be called programmatically.
GME is a stand-alone program that can be started from the Windows Start button -- Programs -- SpatialEcology. It has both a GUI interface (mouse-driven) and a command line interface for scripting.
GME currently has dependencies on R and ArcGIS. Use the table below to identify compatible versions of the software. If you are upgrading any of the dependencies, it is recommended that you use Control Panel to uninstall the old version first.
#2 Wed 10 June 2015 10:55
OhCheat
Re: Arcgis 10.X - Geospatial Modelling Environment (ex-Hawth tools)
Ces outils sont super, je les utilise depuis 2 mois et ils sont très utiles dans le cas où l'on ne bénéficie pas de certaines licences pour faire des traitements basique ! smile
A noter tout de même la difficulté qu'a le logiciel à réaliser des traitements sur un trop grand nombre de données...
Dernière modification par OhCheat (Wed 10 June 2015 10:56)
