#1 Tue 07 July 2015 10:38
GlaDal
QGIS 2.8.2 : Problème d'ouverture du logiciel
j'ai installé hier la version 2.10 via l'OSgeo et suis repassé aujourd'hui en version 2.8.2 mais depuis je n'arrive plus à ouvrir le logiciel et m'indique ce message d'erreur :
  File "", line 1, in
  File "C:/PROGRA~1/QGISWI~1/apps/qgis/./python\qgis\utils.py", line 478, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "C:/PROGRA~1/QGISWI~1/apps/qgis/./python\qgis\user.py", line 42, in
    expressions.load(expressionspath)
  File "C:/PROGRA~1/QGISWI~1/apps/qgis/./python\qgis\user.py", line 19, in load_user_expressions
    __import__("expressions.{0}".format(name), locals(), globals())
  File "C:/Documents and Settings/slemeunier/.qgis2/python\expressions\scratch.py", line 6
    from qgis.core import *
IndentationError: unexpected indent
Version de Python :
2.7.4 (default, Apr  6 2013, 19:54:46) [MSC v.1500 32 bit (Intel)]
Version de QGIS :
2.8.2-Wien 'Wien', 1b929ef
Chemin vers Python :
['C:/PROGRA~1/QGISWI~1/apps/qgis/./python', u'C:/Documents and Settings/slemeunier/.qgis2/python', u'C:/Documents and Settings/slemeunier/.qgis2/python/plugins', 'C:/PROGRA~1/QGISWI~1/apps/qgis/./python/plugins', 'C:\\PROGRA~1\\QGISWI~1\\bin\\python27.zip', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\DLLs', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\plat-win', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\lib-tk', 'C:\\PROGRA~1\\QGISWI~1\\bin', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\PIL', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\jinja2-2.7.2-py2.7.egg', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\markupsafe-0.23-py2.7-win32.egg', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\python_dateutil-2.2-py2.7.egg', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\pytz-2014.2-py2.7.egg', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\win32', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\win32\\lib', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\Pythonwin', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\Shapely-1.2.18-py2.7-win32.egg', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\six-1.6.1-py2.7.egg', 'C:\\PROGRA~1\\QGISWI~1\\apps\\Python27\\lib\\site-packages\\wx-2.8-msw-unicode', u'C:/Documents and Settings/slemeunier/.qgis2//python']
Si quelqu'un peut m'aiguiller, tout aide est la bienvenue.
Merci d'avance,
Gladal
#2 Tue 07 July 2015 10:58
SANTANNA
Lieu: Angers
Re: QGIS 2.8.2 : Problème d'ouverture du logiciel
salut,
il y a un problème d'indentation dans ce fichier C:/Documents and Settings/slemeunier/.qgis2/python\expressions\scratch.py Ouvre-le dans un éditeur de texte et regarde s'il n'y a pas d'espace en début de ligne, auquel cas, enlève-le.
#3 Tue 07 July 2015 11:17
GlaDal
Nop, pas d'espace en début de ligne !
#4 Tue 07 July 2015 11:36
SANTANNA
Lieu: Angers
En switchant entre la 2.10 et la 2.8, j'ai eu le même message mais cela n'a pas empêché la 2.8 de se rouvrir et j'ai noté que le contenu du fichier a changé entre deux. Depuis j'essaie en vain de reproduire le bug. Je passe désormais de l'un à l'autre sans erreur.
Pour ce qui est du contenu du fichier scratch, il n'y a que les commentaires et la ligne return qui sont décalées, les autres sont collées au début (y compris les """)
#5 Tue 07 July 2015 12:08
GlaDal
Voici ce que j'ai dans mon fichier :
    Define new functions using @qgsfunction. feature and parent must always be the
    last args. Use args=-1 to pass a list of values as arguments
    from qgis.gui import *
    @qgsfunction(args='auto', group='Custom')
    def func(value1, feature, parent):
        return value1
Et voici ce que me dit Qgis au chargement qui s’ensuit d'un minidumpage
Impossible de charger qgis.user.
Le support Python va être désactivé.
Dernière modification par GlaDal (Tue 07 July 2015 12:09)
#6 Tue 07 July 2015 12:27
SANTANNA
Lieu: Angers
Et avec ceci?
    return value1
#7 Tue 07 July 2015 13:41
GlaDal
Comment t'as fait ?
Ca marche !
Ravi, je suis ravi !
Quelle est la logique dans ce shmilblik ?
Dans tous les cas, merci pour ton aide SANTANNA (moi aussi un jour, je te rendrai la pareille ! ;-)
#8 Tue 07 July 2015 18:27
SANTANNA
Lieu: Angers
Python est juste très très chatouilleux sur les espaces en début de ligne, ces espaces indiquant que la ligne qui commence comprend des  instructions dépendant de la ligne au dessus. Il s'avère qu'ici, les lignes du dessus ne sont que des commentaires donc peuvent pas être les boss de la suivante, d'où l'erreur signalée.
