#1 Thu 07 January 2016 17:14
mame1985
Lieu: Montréal
ArcPy - Modifier la symbologie
J'essaie de symboliser une couche avec python, mais j'ai pas vue de changement après avoir rédiger le script ci-dessous.
où se trouve alors mon erreur? si quelqu'un la voit je suis bloqué.
>>> import arcpy
>>> mxd = arcpy.mapping.MapDocument("current")
>>> lyr = arcpy.mapping.ListLayers(mxd,"Batiments")[0]
>>> if lyr.symbologyType =="UNIQUE VALUES":
...     lyr.symbology.valueField ="Description"
...     lyr.symbology.addALLValues()
...     arcpy.RefreshActiveView()
...     arcpy.RefreshTOC()
...     del mxd
merci d'avance
Mame
#2 Thu 07 January 2016 20:51
mame1985
Lieu: Montréal
Re: ArcPy - Modifier la symbologie
J'ai trouvé ceci:
The symbologyType on the Layer object is a read-only property. In other words, you can't change a unique values symbology to a graduated colors or graduated symbols symbology. You can only change the properties for a specific symbology class on a layer. The only way to change the symbology type is by publishing the desired result to a layer file and using the UpdateLayer function.
Je vais vérifier.
Mame
#3 Fri 08 January 2016 15:35
mame1985
Lieu: Montréal
J'ai essayé ce code mais il se passe toujours rien;
>>> df = arcpy.mapping.ListDataFrames(mxd)[0]
>>> lyr = arcpy.mapping.ListLayers(mxd,"section")[0]
>>> lyrfile = arcpy.mapping.Layer(r"C:\TEST\section.lyr")
>>> arcpy.mapping.UpdateLayer(df,lyrfile,lyr,"true")
>>> if lyr.symbologyType =="UNIQUE_VALUES":
...     lyr.symbology.valueField ="IDEN_SECTION"
...     del mxd,lyrfile
Dernière modification par mame1985 (Fri 08 January 2016 15:36)
Mame
#4 Fri 08 January 2016 16:52
mame1985
Lieu: Montréal
Arcpy.RefreshTOC"()"
Mame
