#1 Wed 03 April 2019 16:55
Sylvain M.
QGIS/Plugin Cadastre: erreurs rencontrées pendant l'import
J'utilise depuis ses début le plugin Cadastre de QGis, et je remercie au moins une fois par an ses développeurs et financeurs.
En voulant charger les dernières millésimes en ma possession, je rencontre un message d'erreur inhabituel :
Des erreurs ont été rencontrées pendant l'import. Veuillez consulter le log
Et voila les messages dans le panneau "Avertissements Python" du journal des messages :
2019-04-03T16:15:39     WARNING    warning:C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_import.py:1070: ResourceWarning:
             unclosed file
             traceback: File "C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_menu.py", line 218, in open_import_dialog
              dialog.exec_()
              File "C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_dialogs.py", line 1102, in processImport
              qi.installCadastreStructure()
              File "C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_import.py", line 273, in installCadastreStructure
              self.executeSqlScript(s, 'constraints' in item)
              File "C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_import.py", line 1070, in executeSqlScript
              sql = open(scriptPath, encoding="utf-8-sig").read()
2019-04-03T16:15:40     WARNING    warning:C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_import.py:1070: ResourceWarning:
             unclosed file
              dialog.exec_()
             unclosed file
              dialog.exec_()
             unclosed file
              dialog.exec_()
              File "C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_dialogs.py", line 1109, in processImport
              qi.importMajic()
              File "C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_import.py", line 439, in importMajic
              self.executeSqlScript(s, True, 'constraints' in item)
             unclosed file
              dialog.exec_()
              qi.importMajic()
              File "C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_import.py", line 441, in importMajic
              self.executeSqlScript(s, False, 'constraints' in item)
2019-04-03T16:16:45     WARNING    warning:C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_import.py:1070: ResourceWarning:
             unclosed file
              dialog.exec_()
              qi.importMajic()
2019-04-03T16:18:52     WARNING    warning:C:/Users/Sylvain/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\cadastre\cadastre_import.py:1070: ResourceWarning:
             unclosed file
              dialog.exec_()
              qi.importMajic()
Ces logs proviennent de QGis 3.4.2 avec le plugin en version 1.7.0
Mais j'ai eu le même genre d'erreur (sans regarder le log) avec QGis 2.18.13 et le plugin en version 1.5.6
Des idées de la source de mon problème ?
Merci à vous !
Sylvain M.
#2 Wed 03 April 2019 17:02
Sylvain M.
Re: QGIS/Plugin Cadastre: erreurs rencontrées pendant l'import
Au cas où, je me suis permis d'ouvrir une issue sur la page Github du plugin :
https://github.com/3liz/QgisCadastrePlugin/issues/179
A suivre !
Sylvain M.
