#1 Fri 28 June 2019 11:13
Groflo
QGIS 3 [toutes versions]: erreur python pas de plugin processing
De puis quelques temps, à chaque lancement de QGIS, j'ai une erreur me disant qu'il ne peut pas lancer l'extension processing, mais également d'autres plugin. Pour Processing, il me dit : (j'ai mis USER à la place du nom de l'utilisateur)
Impossible de charger l'extension 'processing'
OSError: [WinError 193] %1 n’est pas une application Win32 valide
  File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python\qgis\utils.py", line 312, in loadPlugin
    __import__(packageName)
  File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python\qgis\utils.py", line 737, in _import
    mod = _builtin_import(name, globals, locals, fromlist, level)
  File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python/plugins\processing\__init__.py", line 25, in
    from processing.tools.general import *              # NOQA
  File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python/plugins\processing\tools\general.py", line 32, in
    from processing.core.Processing import Processing
  File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python/plugins\processing\core\Processing.py", line 54, in
    from processing.algs.qgis.QgisAlgorithmProvider import QgisAlgorithmProvider  # NOQA
  File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python/plugins\processing\algs\qgis\QgisAlgorithmProvider.py", line 76, in
    from .HypsometricCurves import HypsometricCurves
  File "C:/PROGRA~1/QGIS3~1.8/apps/qgis/./python/plugins\processing\algs\qgis\HypsometricCurves.py", line 25, in
    import numpy
  File "C:\Users\USER\AppData\Roaming\Python\Python37\site-packages\numpy\__init__.py", line 142, in
    from . import core
  File "C:\Users\USER\AppData\Roaming\Python\Python37\site-packages\numpy\core\__init__.py", line 23, in
    WinDLL(os.path.abspath(filename))
  File "C:\PROGRA~1\QGIS3~1.8\apps\Python37\lib\ctypes\__init__.py", line 356, in __init__
    self._handle = _dlopen(self._name, mode)
Version de Python : 3.7.0 (v3.7.0:1bf9cc5093, Jun 27 2018, 04:59:51) [MSC v.1914 64 bit (AMD64)]
Version de QGIS : 3.8.0-Zanzibar Zanzibar, 11aff65f10
Chemin Python :
C:/Users/USER/AppData/Roaming/QGIS/QGIS3\profiles\default/python
C:/Users/USER/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
C:\Program Files\QGIS 3.8\bin\python37.zip
C:\PROGRA~1\QGIS3~1.8\apps\Python37\DLLs
C:\PROGRA~1\QGIS3~1.8\apps\Python37\lib\site-packages
C:\PROGRA~1\QGIS3~1.8\apps\Python37\lib\site-packages\win32
C:\PROGRA~1\QGIS3~1.8\apps\Python37\lib\site-packages\win32\lib
C:\PROGRA~1\QGIS3~1.8\apps\Python37\lib\site-packages\Pythonwin
C:\Users\USER\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\HCMGIS/forms
C:\Users\USER\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\mmqgis/forms
Pour les autres extensions, c'est plutôt une erreur lors de l'appel à la ClassFactory() dont il me parle.
Après quelques recherches, je présuppose que ça a un lien avec le fait que j'ai (ré)installé du python, notamment quelques IDE, mais sans en être sûr à 100 % et surtout sans trop savoir comment m'en dépatouiller au final !
Si vous avez une idée, je suis preneur, d'autant que le menu processing est quand même fichtrement utile au quotidien !
Merci par avance.
#2 Fri 28 June 2019 11:50
GlaDal
Re: QGIS 3 [toutes versions]: erreur python pas de plugin processing
Bonjour, faites vous vos installations ou mises à jour via l'OSGEO ?
#3 Fri 28 June 2019 13:22
Groflo
Non, je le fais par l'installateur indépendant. Faudrait-il que je teste l'install par OSGeo4W du coup ?
#4 Fri 28 June 2019 16:09
Groflo
Je viens de tester, même résultat.
#5 Fri 28 June 2019 16:20
sylvain poupard
J'avais eu un problème similaire à cause d'un plugin.
Essayez de décocher les dernier plugin installés dans le menu extension, fermez puis rouvrez QGIS.
Bon courage
#6 Fri 28 June 2019 17:28
Groflo
Merci, mais Idem, j'ai décoché à peu près tous les plugins présents depuis le problème (ils n'étaient pas très nombreux) ainsi que ceux qui avaient aussi un problème au démarrage, et pas de mieux…
#7 Fri 28 June 2019 18:00
SANTANNA
Lieu: Angers
menu Options --> Profils utilisateurs --> Nouveau profil utilisateur.
Ca donne quoi?
#8 Wed 03 July 2019 09:02
sylvain poupard
Avez-vous essayé cette procédure?
https://georezo.net/forum/viewtopic.php?pid=310664
Bon courage
#9 Fri 12 July 2019 10:54
Groflo
SANTANNA a écrit:
Ca donne quoi?
Rien de plus, même problème.
sylvain poupard a écrit:
Bon courage
Je ne connaissais pas. Malheureusement, dans mon gestionnaire de périphériques, même en activant les périph cachés, et en testant tous les affichages, je n'ai jamais rien qui ressemble de près ou de loin à des drivers non plug and play dans lesquels trouver le Null en question…
Cela dit, les messages d'erreurs du fil vers lequel vous me renvoyez mentionnaient apparemment explicitement un problème avec Nul, mais moi, je n'ai pas ce message, en revanche j'ai :
Dernière modification par Groflo (Fri 12 July 2019 16:08)
#10 Fri 12 July 2019 11:51
Groflo
Petit up : j'ai désinstallé toutes mes versions de Python et mon IDE, j'ai désinstallé tous mes QGIS existants, et réinstallé un QGIS standalone, puis tout viré et réinstallé par OSgeo4w, y compris en installant toutes les libs proposées, et j'ai la même !
#11 Fri 12 July 2019 20:20
Groflo
Dernier petit up : en installant QGIS standalone 32 bits, ça fonctionne…
C'est un pis aller, mais j'aimerais bien comprendre et faire fonctionner le 64 !
