#1 Mon 30 September 2019 22:53
- Darwin
QGIS 3.4.6: Probleme QBano
[Résolu]
Lorsque je veux charger l'extension QBano sur QGIS 3.4.6 sur mac un message d'erreur surgit :
Impossible de charger l'extension 'QBano' provoque une erreur lors de l'appel à sa méthode classFactory()
ModuleNotFoundError: No module named 'simplejson'
File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 335, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "/Users/darwinaulycee/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/QBano/__init__.py", line 34, in classFactory
from .QBano import QBano
File "/Applications/QGIS3.app/Contents/MacOS/../Resources/python/qgis/utils.py", line 672, in _import
mod = _builtin_import(name, globals, locals, fromlist, level)
File "/Users/darwinaulycee/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/QBano/QBano.py", line 30, in
from .QBano_dialog import QBanoDialog
File "/Users/darwinaulycee/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/QBano/QBano_dialog.py", line 38, in
import simplejson as json
Version de Python : 3.6.8 (v3.6.8:3c6b436a57, Dec 24 2018, 02:04:31) [GCC 4.2.1 Compatible Apple LLVM 6.0 (clang-600.0.57)]
Version de QGIS : 3.4.6-Madeira Madeira, exported
Chemin Python :
/Applications/QGIS3.app/Contents/MacOS/../Resources/python/plugins
/Library/Frameworks/SQLite3.framework/Versions/E/Python/3.6
/Library/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages
/Users/Shared/Lycée/LPA Erstein 1920/BTS/BTS 1/M53/SIG/DIAG Papillon/Projets
/Users/darwinaulycee/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/mmqgis/forms
/Users/darwinaulycee/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins/mmqgis/formsEn espérant trouver de l'aide ici…
Dernière modification par Darwin (Thu 03 October 2019 16:59)
#2 Tue 01 October 2019 08:16
- JD
Re: QGIS 3.4.6: Probleme QBano
le module simplejson doit être dans manquant.
Il faudrait l'installer via pip par exemple.
Je reviens vers vous ce soir avec une procédure.
Bonne journée
#3 Tue 01 October 2019 23:51
- Darwin
#4 Wed 02 October 2019 10:19
- JD
Ouvrez un terminal et tapez les commandes suivantes :
cd /Library/Frameworks/Python.framework/Versions/3.6/bin/ curl -O https://bootstrap.pypa.io/get-pip.py ./python3 get-pip.py pip3.6 install simplejson
Vous devriez voir que la librairie simplejson s'est installée avec succès à la fin.
Ouvrez ou réouvrez QGis et vous ne devriez plus avoir d'erreur.
#5 Thu 03 October 2019 16:58
- Darwin
Merci cela fonctionne
