- Sujet précédent - Tutoriel d'installatioin de Lizmap sur Linux - Sujet suivant
#31 Wed 01 February 2023 23:09
- PauloLrx
Re: Tutoriel d'installatioin de Lizmap sur Linux
La commande donne:
apache2.service - The Apache HTTP Server
Loaded: loaded (/lib/systemd/system/apache2.service; enabled; vendor prese>
Active: active (running) since Fri 2023-01-27 17:29:45 UTC; 5 days ago
Docs: https://httpd.apache.org/docs/2.4/
Process: 401390 ExecStart=/usr/sbin/apachectl start (code=exited, status=0/>
Process: 478949 ExecReload=/usr/sbin/apachectl graceful (code=exited, statu>
Main PID: 401395 (apache2)
Tasks: 37 (limit: 2196)
Memory: 51.7M
CPU: 54.196s
CGroup: /system.slice/apache2.service
├─401395 /usr/sbin/apache2 -k start
├─478960 /usr/sbin/apache2 -k start
├─478963 /usr/sbin/apache2 -k start
├─478964 /usr/sbin/apache2 -k start
├─478966 /usr/sbin/apache2 -k start
├─478967 /usr/sbin/apache2 -k start
├─478968 /usr/sbin/apache2 -k start
├─478969 /usr/sbin/apache2 -k start
├─479029 /usr/sbin/apache2 -k start
└─479034 /usr/sbin/apache2 -k start
janv. 29 00:00:00 localhost systemd[1]: Reloaded The Apache HTTP Server.
lines 1-23
et
<VirtualHost *:80>
# The ServerName directive sets the request scheme, hostname and port that
# the server uses to identify itself. This is used when creating
# redirection URLs. In the context of virtual hosts, the ServerName
# specifies what hostname must appear in the request's Host: header to
# match this virtual host. For the default virtual host (this file) this
# value is not decisive as it is used as a last resort host regardless.
# However, you must set it for any further virtual host explicitly.
#ServerName www.example.com
ServerAdmin webmaster@localhost
DocumentRoot /var/www/html
<Directory /var/www/html/>
Options -Indexes +FollowSymLinks +MultiViews
AllowOverride none
Require all granted
</Directory>
# Available loglevels: trace8, ..., trace1, debug, info, notice, warn,
# error, crit, alert, emerg.
# It is also possible to configure the loglevel for particular
# modules, e.g.
#LogLevel info ssl:warn
ErrorLog ${APACHE_LOG_DIR}/error.log
CustomLog ${APACHE_LOG_DIR}/access.log combined
# For most configuration files from conf-available/, which are
# enabled or disabled at a global level, it is possible to
# include a line for only one particular virtual host. For example the
# following line enables the CGI configuration for this host only
# after it has been globally disabled with "a2disconf".
#Include conf-available/serve-cgi-bin.conf
ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/
<Directory "/usr/lib/cgi-bin/">
AllowOverride None
Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch
Require all granted
</Directory>
# QGIS_AUTH_DB_DIR_PATH must lead to a directory writeable by the Server's FCGI process user
# FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH "/home/qgis/qgisserverdb/"
# FcgidInitialEnv QGIS_AUTH_PASSWORD_FILE "/home/qgis/qgisserverdb/qgis-auth.db"
# Set pg access via pg_service file
# SetEnv PGSERVICEFILE /home/qgis/.pg_service.conf
# Longer timeout for WPS... default = 40
FcgidIOTimeout 120
FcgidInitialEnv LC_ALL "en_US.UTF-8"
FcgidInitialEnv PYTHONIOENCODING UTF-8
# FcgidInitialEnv PYTHONPATH "/usr/share/qgis/python"
FcgidInitialEnv QGIS_SERVER_LOG_STDERR 1
FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0
FcgidInitialEnv QGIS_PLUGINPATH "/var/www/qgis-server/plugins"
<IfModule mod_fcgid.c>
FcgidMaxRequestLen 26214400
FcgidConnectTimeout 60
</IfModule>
</VirtualHost>
#32 Wed 01 February 2023 23:33
- JLH
Merci.
Le serveur fonctionne !
Mais je pense que le problème vient de votre fichier mentionné plus haut.
Tenter de le vider et de le remplacer par :
<VirtualHost *:80>
ServerName localhost
# Apache logs (different than QGIS Server log)
ErrorLog ${APACHE_LOG_DIR}/qgis.demo.error.log
CustomLog ${APACHE_LOG_DIR}/qgis.demo.access.log combined
FcgidIOTimeout 120
FcgidInitialEnv LANG "en_US.UTF-8"
# QGIS log
# default QGIS project
SetEnv QGIS_PROJECT_FILE /home/qgis/projects/world.qgs
FcgidInitialEnv PGPASSFILE "/home/qgis/.pgpass"
# if qgis-server is installed from packages in debian based distros this is usually /usr/lib/cgi-bin/
# run "locate qgis_mapserv.fcgi" if you don't know where qgis_mapserv.fcgi is
AllowOverride None
Require all granted
</Directory>
</IfModule>
</VirtualHost>
(vérifier si votre installation est bien dans /var/www/html pour le paramètre document root)
Dernière modification par Jean HUMBERT (Wed 01 February 2023 23:34)
#33 Fri 03 February 2023 20:28
- PauloLrx
Bonsoir Jean,
Merci pour ces éléments de réponses. Etant novice en linux je ne comprends pas:
quelle instalation s'il vous plait?
Paul-Emmanuel
#34 Sun 12 February 2023 19:32
- PauloLrx
Bonsoir Jean,
Dans /var/www/html j'ai un dossier lizmap qui est en fait un lien symbolique pointant vers
/var/www/lizmap-web-client-3.6.0/lizmap/www
Bonne soirée,
Paul-Emmanuel
#35 Mon 13 February 2023 09:40
- JLH
D'accord, le dossier est au bon endroit.
Avez-vous modifié votre fichier de configuration apache?
#36 Mon 13 February 2023 12:16
- PauloLrx
Bonjour Jean,
Oui absolument.
Bien cordialement,
Paul-Emmanuel
#37 Tue 14 February 2023 08:58
- JLH
Et vous avez toujours le même problème ou cela fonctionne-t-il désormais?
#38 Tue 14 February 2023 09:33
- PauloLrx
Cela ne fonctionne toujours pas malheureusement
#39 Tue 14 February 2023 11:18
- JLH
le message d'erreur est-il le même?
#40 Tue 14 February 2023 17:04
- nworr
L'installeur de lizmap a été lancé ?
php lizmap/install/installer.php
#41 Thu 16 February 2023 18:13
- PauloLrx
J'ai refais la commende et j'ai ce message d'erreur
root@localhost:~# php /var/www/lizmap-web-client-3.6.0/lizmap/install/installer.php
PHP Fatal error: Uncaught Error: Class "DOMDocument" not found in /var/www/lizmap-web-client-3.6.0/lizmap/vendor/jelix/jelix/lib/jelix/core/UrlMapping/XmlMapModifier.php:45
Stack trace:
#0 /var/www/lizmap-web-client-3.6.0/lizmap/vendor/jelix/jelix/lib/jelix/installer/Installer/GlobalSetup.php(202): Jelix\Routing\UrlMapping\XmlMapModifier->__construct()
#1 /var/www/lizmap-web-client-3.6.0/lizmap/vendor/jelix/jelix/lib/jelix/installer/Installer/Installer.php(110): Jelix\Installer\GlobalSetup->__construct()
#2 /var/www/lizmap-web-client-3.6.0/lizmap/vendor/jelix/jelix/lib/jelix/Scripts/InstallerCommand.php(48): Jelix\Installer\Installer->__construct()
#3 /var/www/lizmap-web-client-3.6.0/lizmap/vendor/symfony/console/Command/Command.php(298): Jelix\Scripts\InstallerCommand->execute()
#4 /var/www/lizmap-web-client-3.6.0/lizmap/vendor/symfony/console/Application.php(1040): Symfony\Component\Console\Command\Command->run()
#5 /var/www/lizmap-web-client-3.6.0/lizmap/vendor/symfony/console/Application.php(301): Symfony\Component\Console\Application->doRunCommand()
#6 /var/www/lizmap-web-client-3.6.0/lizmap/vendor/symfony/console/Application.php(171): Symfony\Component\Console\Application->doRun()
#7 /var/www/lizmap-web-client-3.6.0/lizmap/vendor/jelix/jelix/lib/jelix/Scripts/Installer.php(30): Symfony\Component\Console\Application->run()
#8 /var/www/lizmap-web-client-3.6.0/lizmap/install/installer.php(2): Jelix\Scripts\Installer::launch()
#9 {main}
thrown in /var/www/lizmap-web-client-3.6.0/lizmap/vendor/jelix/jelix/lib/jelix/core/UrlMapping/XmlMapModifier.php on line 45
Stack trace:
#0 /var/www/lizmap-web-client-3.6.0/lizmap/vendor/jelix/jelix/lib/jelix/installer/Installer/GlobalSetup.php(202): Jelix\Routing\UrlMapping\XmlMapModifier->__con struct()
Dernière modification par PauloLrx (Thu 16 February 2023 18:17)
#42 Thu 16 February 2023 18:33
- nworr
Il doit manque les extensions php décrites
https://docs.lizmap.com/current/fr/inst … y-packages
php-xml notamment pour le message "DOMDocument" not found
Selon la version php installée (7.4, 8.1, autre)
apt install php7.4-bz2 php7.4-curl php7.4-gd php7.4-intl php7.4-json php7.4-mbstring php7.4-pgsql php7.4-sqlite3 php7.4-xml php7.4-ldap php7.4-redis
ou
apt install php8.1-bz2 php8.1-curl php8.1-gd php8.1-intl php8.1-json php8.1-mbstring php8.1-pgsql php8.1-xml ...
#43 Fri 17 February 2023 09:41
- PauloLrx
En fait, avant d'installer lizmap j'avais installé tous ces fichier php et j'ai la version 8.1, je ne sais pas dans quel dossier linux les stocke...
Ces fichiers doivent-ils être dans un des sous-dossiers de Lizmap?
#44 Fri 17 February 2023 11:08
- nworr
les paquets php8.1-XXX sont installé sur le systeme , donc disponible pour les commandes php.
La commande suivante devraient indiquer le modules "xml" disponibles
php -m | grep xml
#45 Fri 10 March 2023 15:40
- PauloLrx
J'ai réinstallé tout les extension php-xxx et j'ai toujours le message. Website is closed.
#46 Mon 13 March 2023 14:54
- nworr
Toujours le même message de l'installeur ?
#47 Fri 24 March 2023 15:56
- PauloLrx
C'est cela une fois cette commande tapé tout fonctionne. Merci à vous
#48 Tue 11 April 2023 12:21
- Oliv38
je me greffe à ces échanges car je galère aussi avec mon installation avec des erreurs similaires. J'avais déjà installé du Lizmap qui ne nécessitait pas de plugin lizmap_server et qui fonctionnait. Cette fois dans les logs de l'administration lizmap j'ai ces messages :
2023-04-11 10:19:33 [2] Undefined array key "metadata" /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 63 2023-04-11 10:19:33 [2] Trying to access array offset on value of type null /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 63 2023-04-11 10:19:33 [2] Undefined array key "plugins" /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 54 2023-04-11 10:19:33 [2] Trying to access array offset on value of type null /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 54 2023-04-11 10:19:33 [2] Trying to access array offset on value of type null /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 54 2023-04-11 10:19:33 [2] Undefined array key "qgis_server_version_human_readable" /var/www/lizmap-web-client-3.6.2/temp/lizmap/www/compiled/templates/modules/admin/project_list_zone_html_t_15.php 279 2023-04-11 10:19:33 [2] Undefined array key "qgis_server_version_old" /var/www/lizmap-web-client-3.6.2/temp/lizmap/www/compiled/templates/modules/admin/project_list_zone_html_t_15.php 287 2023-04-11 10:19:33 [2] Undefined array key "qgis_server_version_next" /var/www/lizmap-web-client-3.6.2/temp/lizmap/www/compiled/templates/modules/admin/project_list_zone_html_t_15.php 288 2023-04-11 10:19:35 [2] Undefined array key "metadata" /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 63 2023-04-11 10:19:35 [2] Trying to access array offset on value of type null /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 63 2023-04-11 10:19:41 [2] Undefined array key "metadata" /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 63 2023-04-11 10:19:41 [2] Trying to access array offset on value of type null /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 63 2023-04-11 10:20:35 [2] Undefined array key "metadata" /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 63 2023-04-11 10:20:35 [2] Trying to access array offset on value of type null /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 63 2023-04-11 10:20:35 193.56.80.200 error QGIS Serveur doit être mise à jour au moins avec la version 3.10pour cette version de Lizmap Web Client. 2023-04-11 10:20:35 [2] Undefined array key "plugins" /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 54 2023-04-11 10:20:35 [2] Trying to access array offset on value of type null /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 54 2023-04-11 10:20:35 [2] Trying to access array offset on value of type null /var/www/lizmap-web-client-3.6.2/lizmap/modules/lizmap/lib/Server/Server.php 54 2023-04-11 10:20:35 193.56.80.200 error L'extension lizmap_serverdoit être mise à jour.
Pour info le plugin lizmap_server est bien installé et qgis Server est en version 3.22. J'ai pourtant 2 messages d'erreur relatifs...
La version Lizmap client est la 3.6.2 avec du PHP 8.1 normalement tout à fait compatible (pas d'erreur à ce sujet a priori).
Vous auriez une idée du souci ou du moins m'indiquer une méthode pour identifier la source du problème ?
Je vous remercie par avance.
Oliv
#49 Thu 13 April 2023 09:06
- Oliv38
Je répond sur ma demande pour préciser que pour l'installation du plugin lizmap_server (qui semble indispensable) j'ai donc suivi la procédure de la documentation:
sudo pip3 install qgis-plugin-manager cd /usr/lib/qgis/plugins sudo qgis-plugin-manager init sudo cat sources.list https://plugins.qgis.org/plugins/plugins.xml?qgis=3.19 sudo qgis-plugin-manager update sudo qgis-plugin-manager install 'Lizmap server'
Etant donné que j'ai installé qgis server 3.22, faut-il forcément modifier le paramètre "qgis=3.19" en 3.22 ou faut-il prendre une autre version (la dernière ?).
Enfin 2 autres points,
- il semblerait que certaines variables d'environnement soient obligatoires pour le bon fonctionnement, sauf que je n'arrive pas vraiment à savoir lesquels et surtout où faut-il les inscrire (dans mon fichier vhost de qgis-server ?)
- le log error d'apache m'indique l'api Lizmap is not enabled. Comment je la rend "enabled" ?
Une dernière solution serait de régresser ma version de LizmapWeb CLient en 3.5 pour laquelle le plugin lizmap_server n'était pas obligatoire me seble-t-il.
D'avance merci.
Oliv
#50 Thu 13 April 2023 10:05
- nworr
Que dit la page "informations serveur" de l'administration ?
une fois le plugin "lizmap server" installé il faut aussi configurer la variable d'environnement QGIS_SERVER_LIZMAP_REVEAL_SETTINGS dans apache pour que le plugin soit interrogeable
cf https://github.com/3liz/lizmap-web-client/issues/3367
Pour la version indiqué dans le chemin du pluginx.xml j'ai l'impression que ça ne change rien
#51 Thu 13 April 2023 10:48
- Oliv38
Merci pour ta réponse !
La page "informations serveur" me dit ça en bas : QGIS Serveur retourne une erreur HTTP à propos de l'extension Lizmap : 400
Concernant la variable d'environnement que tu cites, en effet je l'avais identifié et j'ai inscrit ceci dans mon fichier vhost ssl :
<IfModule mod_ssl.c> <VirtualHost *:443> ServerAdmin webmaster@localhost ServerName DocumentRoot /var/www/html <Directory /var/www/html/> Options -Indexes +FollowSymLinks +MultiViews AllowOverride none Require all granted </Directory> # Apache logs (different than QGIS Server log) ErrorLog ${APACHE_LOG_DIR}/qgis-server.error.log CustomLog ${APACHE_LOG_DIR}/qgis-server.access.log combined # Longer timeout for WPS... default = 40 FcgidIOTimeout 120 FcgidInitialEnv LC_ALL "en_US.UTF-8" FcgidInitialEnv PYTHONIOENCODING UTF-8 FcgidInitialEnv LANG "en_US.UTF-8" # QGIS log FcgidInitialEnv QGIS_SERVER_LOG_STDERR 1 FcgidInitialEnv QGIS_SERVER_LOG_LEVEL 0 # default QGIS project # SetEnv QGIS_PROJECT_FILE /home/qgis/projects/world.qgs # QGIS_AUTH_DB_DIR_PATH must lead to a directory writeable by the Server's FCGI process user FcgidInitialEnv QGIS_AUTH_DB_DIR_PATH "/home/qgis/qgisserverdb/" FcgidInitialEnv QGIS_AUTH_PASSWORD_FILE "/home/qgis/qgisserverdb/qgis-auth.db" # Set pg access via pg_service file SetEnv PGSERVICEFILE /home/qgis/.pg_service.conf FcgidInitialEnv PGPASSFILE "/home/qgis/.pgpass" # Plugins FcgidInitialEnv QGIS_PLUGINPATH "/usr/lib/qgis/plugins/" FcgidInitialEnv QGIS_SERVER_LIZMAP_REVEAL_SETTINGS=True # if qgis-server is installed from packages in debian based distros this is usually /usr/lib/cgi-bin/ # run "locate qgis_mapserv.fcgi" if you don't know where qgis_mapserv.fcgi is ScriptAlias /cgi-bin/ /usr/lib/cgi-bin/ <Directory "/usr/lib/cgi-bin/"> AllowOverride None Options +ExecCGI -MultiViews -SymLinksIfOwnerMatch Order allow,deny Allow from all Require all granted </Directory> <IfModule mod_fcgid.c> FcgidMaxRequestLen 26214400 FcgidConnectTimeout 60 </IfModule> SSLCertificateFile /etc/letsencrypt/live/ /fullchain.pem SSLCertificateKeyFile /etc/letsencrypt/live/ /privkey.pem Include /etc/letsencrypt/options-ssl-apache.conf </VirtualHost> </IfModule>
Est-ce qu'il y a des trucs choquant là dedans ?
Merci encore
#52 Thu 13 April 2023 11:11
- Oliv38
Mais oui, la révélation !
Merci pour ton aide, je n'utilisais pas la bonne syntaxe de déclaration pour cette variable d'environnement. Il faut donc mettre :
- FcgidInitialEnv QGIS_SERVER_LIZMAP_REVEAL_SETTINGS True
ou
- FcgidInitialEnv QGIS_SERVER_LIZMAP_REVEAL_SETTINGS "1"
Et tout rentre dans l'ordre, je peux enfin afficher ma carte.
Merci beaucoup.
#53 Thu 13 April 2023 11:27
- nworr
Oui la doc en confusante, des correction sont en cours.
Dernière modification par nworr (Thu 13 April 2023 11:50)
#54 Thu 13 April 2023 11:50
- Oliv38
Ca me renvoie ça :
-------------------------------------------------------------------------------------------------------------- | Folder ⬇ | Name | Version | Flags | QGIS min | QGIS max | Author | Folder rights | Action ⚠ | -------------------------------------------------------------------------------------------------------------- |lizmap_server|Lizmap server|2.7.0 |Server |3.10 |3.99 |3Liz |www-data : 0o755 | | --------------------------------------------------------------------------------------------------------------
Pour l'interrogation .json j'ai une erreur NOT FOUND The requested URL was not found on this server.
#55 Thu 13 April 2023 13:57
- nworr
Entre temps j'ai édité mon message, désolé
Dernière modification par nworr (Thu 13 April 2023 13:58)
#56 Tue 13 June 2023 13:32
- Oliv38
je réouvre ce post car pour une nouvelle install Lizmap j'ai quelques soucis à peu près pour les mêmes raisons que précédemment.
J'ai installé Qgis_server 3.28, ça tourne bien.
J'ai installé Lizmap Web Client, l page web d'administration s'ouvre parfaitement.
J'ai installé manuellement (sans passé par qgis-plugin manager car j'y arrivais pas) le plugin 'lizmap server' en version 2.7.2 en le dézippant dans le dossier "/usr/lib/qgis/plugins/"
root@server:/usr/lib/qgis/plugins# qgis-plugin-manager list QGIS version : 3.28.7 List all plugins in the current working directory : /usr/lib/qgis/plugins The 'update' command has not been done before. The repository https://plugins.qgis.org/plugins/plugins.xml?qgis=3.28 has not been fetched before. ------------------------------------------------------------------------------------------------------------------------- | Folder ⬇ | Name | Version | Flags | QGIS min | QGIS max | Author | Folder rights | Action ⚠ | ------------------------------------------------------------------------------------------------------------------------- |lizmap_server|Lizmap server|2.7.2 |Server |3.10 |3.99 |3Liz |www-data : 0o755 |Remote unknown| -------------------------------------------------------------------------------------------------------------------------
J'ai aussi pris soin de déclarer la variable d'environnement QGIS_SERVER_LIZMAP_REVEAL_SETTINGS True dans mon VHOST
Et pourtant, j'ai une erreur :
dans la page d'amdinistration Lizmap : QGIS Serveur retourne une erreur HTTP à propos de l'extension Lizmap : Unknown
dans les fichiers logs lizmap : 2023-06-13 13:14:50 10.38.4.103 error QGIS serveur minimum 3.10 et l'extension Lizmap QGIS Serveur 2.7.1 doivent être installés et configurés correctement. Votre serveur QGIS n'est pas joignable correctement en utilisant l'URL "http://ip_server/cgi-bin/qgis_mapserv.fcgi".
Auriez-vous une piste de résolution à me suggérer ? Serait-ce la version 2.7.2 qui coince avec qgis server 3.28 ?
D'avance merci si vous avez une idée.
#57 Tue 13 June 2023 13:47
- Oliv38
Je vous confirme que le changement de version vers 2.7.1 ne change rien
#58 Tue 13 June 2023 16:11
- nworr
Dans le navigateur ou en lige de commande (curl) le serveur Qgis renvoie quelque chose ?
http://<ip_server>/cgi-bin/qgis_mapserv.fcgi/lizmap/server.json
#59 Tue 13 June 2023 16:27
- Oliv38
merci à toi.
Cela renvoie ceci :
<ServiceExceptionReport version="1.3.0"> <ServiceException code="Service configuration error"> Service unknown or unsupported. Current supported services (case-sensitive): WMS WFS WCS WMTS SampleService, or use a WFS3 (OGC API Features) endpoint </ServiceException> </ServiceExceptionReport>
#60 Tue 13 June 2023 17:18
- Oliv38
Sur la page "information serveur" de l'administration Lizmap il est noté :
Nous ne pouvons avoir les détails sur l'installation de votre serveur QGIS (version, extensions etc.).
Se peut-il qu'il y ai des problèmes de droits quelque part ? Si oui où ?
Apache est propriétaire de la plupart des dossiers plugin, lizmap, répertoire projets, vhost.
Lors de l'installation de 'Lizmap server' j'ai eu une alerte comme quoi j'avais fait l'installation avec root.
Merci encore pour l'aide.
Dernière modification par Oliv38 (Tue 13 June 2023 17:18)
