- Sujet précédent - EPSG Version 6.10 geodetic parameter dataset (free download) - Sujet suivant
#1 Thu 04 May 2006 04:25
Pour info
__________________________________________________________________
EPSG geodetic parameter dataset v6.10 release
Version 6.10 of the EPSG geodetic parameter dataset was released in April 2006 and may be downloaded without charge from www.epsg.org. This release contains a number of additions to data in the previous v6.9 (Feb 2006) release as well as the following:
Changes as documented in Change table records through 2006.29, but with actions still remaining on some earlier change requests.
Transformations included in the Guidance Note on Transformations for the Gulf of Mexico published by the Americas Petroleum Survey Group (APSG)
Data not previously available in EPSG database for Data for Alaska, Greenland, Faroe Islands, Finland, Mauritania, Mauritius and Malaysia
Typographic corrections to projection formulae for Oblique Stereographic, Lambert Azimuthal Equal Area, Albers Equal Area, Modified Azimuthal Equidistant, Krovak, and Cassini projection methods. Similar corrections have been made to Guidance Note 7 part 1 – Use of the EPSG Geodetic Parameter Dataset.
As for previous releases, the v6.10 dataset is available in two forms: either an MS Access database which also includes a data reporting capability, or as a series of SQL scripts for populating an alternative relational database application. There are several different SQL scripts for different SQL variants. In each format, the v6.10 release is accompanied by an updated version of the ReadMe file, in both PDF and MS Word formats.
If you have not seen this earlier, please note that the former European Petroleum Survey Group reformed last year as the Surveying and Positioning Committee of the International Association of Oil and Gas Producers (OGP). Similarly, the EPSG Geodesy Working Group has become the Geodesy Subcommittee of the OGP Surveying and Positioning Committee. This Geodesy Subcommittee continues with the same members as the previous EPSG Geodesy Working Group. This OGP Geodesy Subcommittee will continue to maintain the EPSG dataset. The dataset will continue to be known as the EPSG (geodetic parameter) dataset.
Best regards,
Jim Cain,
Member, Geodesy Subcommittee of the OGP Surveying and Positioning Committee
Chairman, Americas Petroleum Survey Group (APSG)
Cain & Barnes, L.P.
Houston, TX 77077-3910 USA
Tel: +1 (281)-558-6153, Mob: +1 (832)-215-5551, Fax: +1 (281)-556-1084
Preferred EPSG / OGP incoming email address: jim.cain@cain-barnes.com
Dernière modification par Franck B (Thu 04 May 2006 04:26)
#2 Thu 04 May 2006 13:32
- Pascal Boulerie
- Lieu: France
- Site web
Re: EPSG Version 6.10 geodetic parameter dataset (free download)
> [...] Version 6.10 of the EPSG geodetic parameter dataset was released in April 2006
> and may be downloaded without charge from http://www.epsg.org.
Pour ceux qui comme moi ne pourront pas accéder au site en question / n'auront pas le droit de le consulter *, je me bornerai à noter que EPSG : European Petroleum Survey Group (comme cela était indiqué dans le texte). Il s'agit donc d'un domaine d'application tres specifique et particulier / restreint qui n'intéressera pas l'utilisateur lambda.
* "You are not authorized to view this page
You do not have permission to view this directory or page due to the access control list (ACL) that is configured for this resource on the Web server."
#3 Thu 04 May 2006 14:18
Non pas du tout. D'abord le site doit avoir un problème l'ayant déjà parcouru ! Normalement tous le monde y accès sans restriction comme indiqué dans le mail de départ.
Ensuite le domaine d'application. Il s'agit à partir d'un code (code EPSG), de définir les projections dont les paramètres ne sont pas forcément connus de tous. Ainsi Grass, mapserver et plusieurs autres logiciels libre utilisent ce code pour
simplifier la création de projet dont on doit définir une projection. Ainsi pour lambert 93 il suffit d'entrer le code 2154. Cela simplifie énormément les choses.
Dernière modification par yjacolin (Thu 04 May 2006 14:19)
#4 Thu 04 May 2006 17:12
- jean-francois Behm
- Lieu: Toulouse
- Site web
Non cela peut interesser tous ceux qui utilisent les codes EPSG pour les
projections ou qui travaillent sur des données hors de France.
il s'agit d'une base de données, certes créée par des compagnies pétrolières
mais qui renseigne sur la quasi-totalité des projections rencontrées dans le
monde.
Les codes des projections tendent à devenir un standard. ils sont par
exemple utilisés dans Mapserver.
#5 Fri 05 May 2006 17:56
- F Aumonier
- Invité
Effectivement, c'est notamment cette bibliothèque que nous utilisons pour
faire nos reprojections à la volée, elle est donc très utile y compris pour
des éditeurs français !
FA
