Retour
Contenu de generalprefform.eng à traduire :
   1 "Main Window" @
   2 "Main Window|Position & Size" @
   3 "Map Window" @
   4 "Map Window|Display" @
   5 "Map Window|Display|Raster Maps" @
   6 "Map Window|Display|Segment Maps" @
   7 "Map Window|Display|Polygon Maps" @
   8 "Map Window|Display|Point Maps" @
   9 "Map Window|Default Representations" @
  10 "Map Window|Position & Size" @
  11 "Map Window|Editors" @
  12 "Map Window|Editors|Point Editor" @
  13 "Map Window|Editors|Segment Editor" @
  14 "Table Window" @
  15 "Table Window|Graph Window" @
  16 "Font" @
  17 "Font|General Font" @
  18 "Font|Dialog Font" @
  19 "Font|Table Font" @
  20 "Font|Graphs Font" @
  21 "Directories" @
  22 "Advanced" @
  23 "General" @
 100 "Commandline" @
 101 "&History entries" @
 102 "Show a &Raster map definition form when calculating" @
 103 "&Show" @
 104 "Default double-click actions" @
 105 "&Filter" @
 106 "&Map List" @
 107 "&X Position" @
 108 "&Y Position" @
 109 "&Width" @
 110 "&Height" @
 111 "Digitizer" @
 112 "&Tool Directories" @
 113 "&Script Directories" @
 114 "Directory for &Log file" @
 115 "&Default Startup dir" @
 116 "&Show display options when opening a map" @
 117 "Default Colors for domain Bool" @
 118 "&True" @
 119 "&False" @
 120 "Show Display Options dialog box for:" @
 121 "&All Raster maps" @
 122 "using domain &Image" @
 123 "using domain &Value" @
 124 "using domain &Class/ID" @
 125 "using domain &Bool" @
 126 "using &other domains" @
 127 "&All Segment maps" @
 128 "&All Polygon maps" @
 129 "&All Point maps" @
 130 "Dialog Font" @
 131 "General Font" @
 132 "Table Font" @
 133 "Graph Font" @
 134 "&Show Command Line when showing non-tables" @
 135 "Default position and size of Table Window" @
 136 "General Options" @
 137 "Advanced" @
 138 "Error" @
 139 "Delete not possible, Administrator rights required" @
 140 "Create Pyramid Layers by default" @
 141 "Pyramid Layers" @
 142 "&Stereo Pair" @
 143 "Default position and size of Main Window" @
 144 "Default position and size of Map Window" @
 145 "Default position and size of Graph Window" @
 146 "Point Editor" @
 147 "Segment Editor" @
 148 "Restore Defaults" @
 149 "Use old style  progress indicators during operations and scripts" @
 200 "The font that is used in the Main Window, in Catalogs" @
 201 "and in data windows" @
 202 "The font that is used in all dialog boxes" @
 203 "<Not used>" @
 204 "The font that is used in all tables." @
 205 "The font that is used in all graphs." @
 206 "This item contains subentries, please expand." @
 207 "To remove user-specific registry keys upon exit" @
 208 "i.e. all default settings will be restored upon exit." @
 300 "&Reset" @
 301 "Give a &Warning when an object is opened which is not up-to-date" @
 302 "Restore defaults" @
main/logiciels/ilwis/fichiers/generalprefform.eng.txt · Dernière modification: 2009/04/16 18:17 (modification externe)
