Retour
Contenu de mapwind.eng à traduire :
   1 "Add Raster Map" @
   2 "Add Segment Map" @
   3 "Add Polygon Map" @
   4 "Add Point Map" @
   5 "Save View As" @
   6 "Add Bitmap or Picture" @
   7 "Extend Window by Coordinates" @
   8 "Change Coordinate System" @
   9 "Extend Window by Percentage" @
  10 "Layer Management" @
  11 "Add Data Layer" @
  12 "Add Annotation" @
  13 "Edit Raster Map" @
  14 "Edit Segment Map" @
  15 "Edit Polygon Map" @
  16 "Edit Point Map" @
  17 "Save Raster Map As" @
  18 "Paste As" @
  19 "Add Annotation Text" @
  20 "Background" @
  21 "Double Click Action" @
  22 "Show Map List" @
  23 "Print" @
  24 "Scale" @
  25 "Layer Management" @
  26 "Attributes" @
  27 "Histogram of %S" @
  28 "Overview window" @
 100 "Remove %SnAre you sure?" @
 101 "Remove Layer" @
 102 "Replace Coordinate System" @
 103 "Replace Coordinate System of %S (now %S) with %S?" @
 104 "Show map list %S as" @
 105 "Replace Georeference" @
 106 "Printing will use %i page(s)" @
 107 "Distance calculation impossible" @
 108 "Distance" @
 109 "Direction" @
 110 "degrees" @
 111 "Spherical Distance" @
 112 "Spherical Azimuth" @
 113 "Ellipsoidal Distance" @
 114 "Ellipsoidal Azimuth" @
 115 "Distance on map" @
 116 "Azimuth on map" @
 117 "From %S" @
 118 "To %S" @
 119 "Scale Factor" @
 120 "Save Changes" @
 121 "Save the changes you made to Map View '%s'?" @
 122 "Meridian Convergence" @
 200 "Map Error" @
 201 "GeoReference not Valid" @
 202 "Drop Object" @
 203 "Error" @
 204 "Can't edit backup file" @
 205 "Map List Error" @
 206 "Rastermap is too large to print" @
 207 "Print error" @
 208 "Coordinate System not Valid" @
 209 "Coordinate system not usable here" @
 210 "Printing would need too many pages" @
 211 "No possible Legend" @
 212 "Incorrect Background Map, editing not possible" @
 213 "GeoReference %S is read-only and thus cannot be edited" @
 214 "No Background Map specified, editing not possible" @
 215 "Raster Map to Add does not have same GeoReference" @
 216 "%S cannot be added as a layer" @
 300 "Drag objects to change order" @
 301 "Add Layer" @
 302 "Add Annotation" @
 303 "Redrawing, Press ESC to interrupt" @
 304 "  No Coordinates" @
 305 "  No Coordinates calculated" @
 306 "Loading ..." @
 307 "No Scale" @
 400 "&Map View Name" @
 401 "&Title" @
 402 "&Isotropic" @
 403 "Minimum X" @
 404 "Mininum Y" @
 405 "Maximum X" @
 406 "Maximum Y" @
 407 "Percentage at &Top" @
 408 "Percentage at &Bottom" @
 409 "Percentage at &Left" @
 410 "Percentage at &Right" @
 411 "&Show" @
 412 "&Info" @
 413 "Add &Map" @
 414 "Display &Options" @
 415 "Add &Annotation" @
 416 "&Remove" @
 417 "&Grid Lines" @
 418 "&Graticule" @
 419 "&Scale Bar" @
 420 "&North Arrow" @
 421 "&Single Text" @
 422 "&Legend" @
 423 "&Bitmap or Picture" @
 424 "&Raster Map Name" @
 425 "&Description:" @
 426 "&Box" @
 427 "Minimum X, Y" @
 428 "Maximum X, Y" @
 429 "Paste As" @
 430 "&Picture" @
 431 "&Bitmap" @
 432 "&Create..." @
 433 "&Text Layer" @
 434 "&Background" @
 435 "Double Click to" @
 436 "&Edit Attribute" @
 437 "Edit &Representation" @
 438 "Execute &Action" @
 439 "Copy to Clipboard" @
 440 "Area to Copy" @
 441 "&Entire Map" @
 442 "&Current Window" @
 443 "Add data layer" @
 444 "&Color Composite" @
 445 "&Slide Show" @
 446 "Area to Print" @
 447 "Paper" @
 448 "Fit on &Page" @
 449 "&Scale 1 :" @
 450 "&Gamma Factor" @
main/logiciels/ilwis/fichiers/mapwind.eng.txt · Dernière modification: 2009/04/16 18:19 (modification externe)
