Strict Standards: Declaration of syntax_plugin_tag_tag::handle() should be compatible with DokuWiki_Syntax_Plugin::handle($match, $state, $pos, Doku_Handler $handler) in /var/www/html/web/wiki/lib/plugins/tag/syntax/tag.php on line 118
Strict Standards: Declaration of syntax_plugin_tag_tag::render() should be compatible with DokuWiki_Syntax_Plugin::render($format, Doku_Renderer $renderer, $data) in /var/www/html/web/wiki/lib/plugins/tag/syntax/tag.php on line 118
Strict Standards: Only variables should be assigned by reference in /var/www/html/web/wiki/lib/plugins/tag/syntax/tag.php on line 79
Sélectionner par style d'objet
  • Problème
- sélectionner par style
  • Solution
main/logiciels/mapinfo/faq/12.txt · Dernière modification: 2009/04/15 20:59 (modification externe)
