#1 Tue 17 March 2015 10:10
verdon
QGIS 2.6 : Erreur à l'ouverture du gestionnaire de Base de Données
Lorsque je cherche à ouvrir le Gestionnaire de base de données (anciennement DBManager dans la version 1.8 Lisboa que j'utilisais avant), une erreur python s'affiche :
Une erreur est apparue lors de l'exécution du code Python :
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_model.py", line 404, in rowCount
    self._refreshIndex( parent, True )
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_model.py", line 456, in _refreshIndex
    if item.populate():
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_model.py", line 151, in populate
    if not connection.connect():
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_plugins\postgis\plugin.py", line 101, in connect
    return self.connectToUri(uri)
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_plugins\plugin.py", line 94, in connectToUri
    self.db = self.databasesFactory( self, uri )
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_plugins\postgis\plugin.py", line 68, in databasesFactory
    return PGDatabase(connection, uri)
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_plugins\postgis\plugin.py", line 135, in __init__
    Database.__init__(self, connection, uri)
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_plugins\plugin.py", line 173, in __init__
    self.connector = self.connectorsFactory( uri )
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_plugins\postgis\plugin.py", line 138, in connectorsFactory
    return PostGisDBConnector(uri)
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_plugins\postgis\connector.py", line 56, in __init__
    raise ConnectionError(e)
  File "C:/PROGRA~1/QGISBR~1/apps/qgis/./python/plugins\db_manager\db_plugins\plugin.py", line 41, in __init__
    msg = unicode( msg, 'utf-8' )
UnicodeDecodeError: 'utf8' codec can't decode byte 0xe9 in position 42: invalid continuation byte
Version de Python :
2.7.5 (default, May 15 2013, 22:44:16) [MSC v.1500 64 bit (AMD64)]
Version de QGIS :
2.6.0-Brighton Brighton, exported
Avez vous une idée de la raison de cette erreur ??
#2 Tue 17 March 2015 10:22
PA
Lieu: Paris
Re: QGIS 2.6 : Erreur à l'ouverture du gestionnaire de Base de Données
Extension à mettre à jour ?
#3 Tue 17 March 2015 13:19
verdon
Apparemment elle ne fait pas partie des extensions à mettre à jour. J'ai la version 0.1.20.
L'erreur apparait lorsque j'essaie de me connecter à POSTGIS Server.
#4 Tue 17 March 2015 14:03
SANTANNA
Lieu: Angers
Un problème d'accent peut-être dans le nom du serveur?
#5 Tue 17 March 2015 15:04
verdon
En fait cela fonctionne très bien avec la version 1.8 et c'est la même version de DBManager dans les deux QGis. Je n'ai pas d'accent dans le nom de mon serveur PostGis.
Mon soucis c'est que je suis obligé de jongler entre les deux versions pour obtenir ce que je veux. Je crée une couche résultat d'une requête select dans 1.8 et ensuite j'ouvre le projet en 2.6 car j'applique un style dont la couleur se trouve dans les attributs (fonctionnalité absente de 1.8).
C'est pas très pratique ....
#6 Tue 17 March 2015 15:17
verdon
J'ai reconfiguré la connexion PostGis en enregistrant le mot de passe (du coup il est en clair dans le fichier) et miracle cette fois ci je n'ai plus les erreurs python. Cela devait être une erreur à l'ouverture de la connexion où il ne devait pas avoir toutes les infos (??).
Le problème est donc résolu.
